08-05-2021 22:17
08-05-2021 22:17
Charged my Sense overnight, took it off the charger with 100% battery at 5am. Worked and bathed 8 horses done around 11am. Came home took my Sense off and cleaned it of sweat and dust and the battery was at 80% which is normal since I live in West Texas where our temps have been 95+. Didn't notice until around 4pm that it was dead and not responding. I tried restarting it, put it on the charger to see if that would jump start it. All pins on Charger clean. According to my app the last sync was 11:30am. I did notice that all this week the battery had been draining rapidly.
08-06-2021 04:23
08-06-2021 04:23
This rapid discharging is a new common fault and so is the problem with the pins on the charger adapter.
For the latter check the 4 pins are equally prominent.
For the rapid discharge there is nothing you can do till Fitbit fix it. May be turning off the phone's Bluetooth when you can will help.
Probably best to inform Fitbit Support directly.
Best Answer08-06-2021 22:11
08-06-2021 22:11
Thanks, I tried a few fixes and luckily it's working again 😁 I did turn off the Bluetooth and cleaned the pins plus plugged it into a wall charger. I did leave it on the charger all night and day. Thankful I don't have to send it in!
08-06-2021
22:30
11:26
08-06-2021
22:30
11:26
Normally the watch should only take about an hour to charge.
If it takes longer than that there may be an issue with the 4 pins on the charger, inspect carefully for signs of abnormalities.
Also just in case try a shutdown of the watch and put it back on charge to start it.
