07-23-2022 10:09
07-23-2022 10:09
Bought the sense about a week ago. The battery seems to die within a day a half. I charged it to full yesterday and it's been less than 24 hours and the battery is at least than 50%. I have an Android, Google pixel 6 pro.
Best Answer07-23-2022 11:24
07-23-2022 11:24
Hi @shanked88 - it depends on what features you used and how it is setup. For example Snore detection and SpO2 tracker app can use as much as 4 days per charge - see more details in How to resolve the Major issues causing short battery life.
07-23-2022 11:44
07-23-2022 11:44
I do use the sleep functions. Maybe I'll turn that off when I'm having periods of time where I'm feeling well. Just use it to help deduce if my feeling tired or unwell is due to sleep.
Thanks, I'll look more into it.
17:59
07:55
07-23-2022
17:59
07:55
@shanked88 - I have found that sleep uses the battery less, if things like snore detection and SpO2 are disabled.
Presumably because the watch is set to dim mode when sleep is enabled and there are less frequent watch wakes (which have to be done manually).
