11-14-2023
06:28
08:00
11-14-2023
06:28
08:00
All of a sudden my Sense battery is draining fast
11-14-2023 08:41
11-14-2023 08:41
Hi there, @K-Bates. Welcome to the Fitbit Community Forums. I'm sorry to hear that your Sense battery is draining too quickly. I understand where your concern is coming from, I'll be glad to help you!
Are you using Snore Detection? If so, please note that the Snore Detection feature does impact your device’s battery, so we recommend charging your device to at least 40% before going to bed. For more information, see How can I use my Fitbit device to detect snoring and noise levels while I sleep?
However, I'd like to share with you that the battery life will depend on how frequent certain features are used in general. Because you're using an Always-On Display clock face, I'd recommend changing the clock face to another one made by Fitbit and monitor your it's behavior in the next day. Additionally, try turning off this setting by opening the Settings app on your watch > Display > Always-on display.
Hope this helps.
11-14-2023 08:41
11-14-2023 08:41
Hope this helps.
11-17-2023 17:43
11-17-2023 17:43
Hi k-Bates
my fitbit sense is doing the same thing. I have bought a new charger to check and after charging it, restarting etc.. its been about 6 hours and its 8% 🫠 Gutted as this Watch costed heaps.
11-18-2023 06:51 - edited 11-18-2023 06:51
Hi there, @kalokeekz. Welcome on board. I'm sorry to hear that your Sense is still not holding a charge after buying a new charger and the steps you've tried so far. I understand how you must be feeling.
To better assist you, would you mind confirming or trying the tips and recommendations I've shared here? Please note some features mentioned there can be impacting your device's battery life.
Looking forward to hearing from you.
