I have had fitbits for years and swapped from the charge series to the sense earlier this year, the battery life only seems to last 2 days and I and having to charge it every other night where as the charge was every week, could the battery be faulty?
Best AnswerHi @Abi_miller It could be, but it depends on how you are using it and what you have turned on. I also have a Sense and mine lasts 5 or 6 days without running it down to the critical level. I don't use GPS or other battery using apps or watch faces etc. You would be best to contact Fitbit Support and see what they think. Good luck with it
Helen | Western Australia
