11-04-2021
11:58
08:18
11-04-2021
11:58
08:18
Hi fitbit team,
My new sense fitbit charger has problem, it is not charging the watch properly. I have to connect and reconnect for charging to happen. Today onwards it has stopped charging......please help.
11-04-2021
14:07
06:04
11-04-2021
14:07
06:04
Hi, if it won't charge the battery will be flat and it can't be started.
Check the 4 pins on the charger, to see if they are equally prominent and well located. It is often a cause of not charging.
If it's faulty get a replacement charge cable under warranty.
11-05-2021 08:20 - edited 09-14-2023 09:50
Hi there, @pramod_chavan. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Sense's charger.
I've seen you contacted our Support Team after posting here and they're now helping you with this issue. Please stay tuned to your inbox, someone will reach out to your soon. Nevertheless, I suggest to not keep replying to the last email you received from our team as you're sending you case back to the queue every time you update it, so please wait until you hear back from them.
