My sense been stuck trying to load the same clock face I had selected to change it to days ago and it just seems to be taking forever for the Fitbit app to sync the change in clock face I had selected days ago. It really should not be taking hours and hours to make the switch between various clock faces a user wishes to change their device to be on display on the watch.
This can happen - to clear it
In Android phone Settings * Apps Fitbit Storage - clear cache [not data] Force Fitbit shutdown [though it doesn't seem to fully] Log back in to the Fitbit app
*Quick Shortcut: Press and hold the Fitbit launch icon, then App info [on some phones] |
Or for IOS uninstall/reinstall the Fitbit App, and redo notification setup.
The trick to a more successful clock change is to make sure your watch is syncing and synced, and to perform a sync if the clock doesn't load. It can often be problematic if the watch is having syncing problems.
In the Fitbit App, Pull down to refresh,
Click on profile photo [top left] Device photo [middle left] Sync Check it says "a moment ago", if not Click on the circle, to resync |
