01-20-2021
11:50
06:08
WilsonFitbit
01-20-2021
11:50
06:08
WilsonFitbit
My sense would have a timer for 30 minutes and have a blank screen. Watch would vibrate when button pressed but no visible screen. After a while the watch would restart and the timer would stop.
I think my watch crashes any suggestions?
Best Answer01-20-2021 16:42
01-20-2021 16:42
My first thought would have been to try a restart, but this should happen after every crash.
My next thought would be to shut down the Sense, then turn it on.
Best Answer01-21-2021 06:04
01-21-2021 06:04
Hello @Kevin.rn.fit Welcome to the Community Forums! @Rich_Laue Thanks for the input!
I was able to see that @Rich_Laue provided information about your inquiry. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Have a nice day!
Best Answer01-26-2021 06:19
01-26-2021 06:19
I have the same issue and sadly a simple restart does not fix this. I have had to stop using the timer. I've been hoping for an update to the device to fix this issue.
Best Answer01-26-2021 09:46
01-26-2021 09:46
Are you trying the simple, hold in the button restart, or a complete shutdown.
A complete shutdown is the only way to reset hardware.
01-27-2021 05:51 - edited 01-27-2021 05:55
@Raeraegood Welcome to the Community Forums! Thank you for following some troubleshooting steps! @Rich_Laue Thank you very much for your input!
@Raeraegood If the inconvenience persists, the best way to get help for this, is to chat with our Support Team or give a call. Click here to get connected. Please make sure to mention the troubleshooting steps you've followed so they can assist you from there.
Have a great day!
