01-30-2022 05:41
01-30-2022 05:41
I charged my sense last night to 98% and shut it down. When I turned it ON this morning it was starting at 77%.
What's going on here? Anyone facing similar issues?
Best Answer01-30-2022 06:43
01-30-2022 06:43
Hi, @nandsun, welcome to the community, can you please clarify what you mean by "When I turned it ON this morning". I would assume you leave it on and wear it overnight. During this time there will be battery drain as the device records your HR, sleep pattern and other metrics and syncs with your phone Fitbit app. You note a drain of 21% if you have something like the "Snore report" activated you will know this adds to the battery drain.
We look forward to hearing from you.
Cheers
Gr4ndp4 | UK
01-30-2022 07:47
01-30-2022 07:47
Hi @nandsun - in addition to what @Gr4ndp4 says check all the options in the list How to resolve the Major issues causing short battery life.
