01-15-2022
07:10
10:59
EstuardoFitbit
01-15-2022
07:10
10:59
EstuardoFitbit
Hello! I got a Sense for Christmas to replace a Versa. The Sense does not count calories burned the same 😞 I do kickboxing twice a week and with the Versa my calories burned were like 260 and my weight/circuit workouts like 263. Now with the Sense kickboxing registering 200 and my other workouts 136. Why is this?? Makes me sad about the change.
Best Answer01-15-2022 09:08
01-15-2022 09:08
@DeniseC326 That would be because of the low heart rate issue during exercise. If you search the forum, you'll find threads, mostly locked, about it.
Best Answer01-15-2022 09:11
01-15-2022 09:11
My heart rate hasn't changed during exercise....my question is why it's calculating differently from the versa to the sense...
Best Answer01-15-2022 09:24 - edited 01-15-2022 09:28
@DeniseC326 It's different technology. Sense and Versa 3 have a newer heart rate sensor called pure pulse 2. Fitbit advertised it as being more accurate.
Best Answer01-15-2022 09:29
01-15-2022 09:29
Yes I see what you're saying now after searching the topic (which I should have done first ).
Bummer that so many are experiencing issues with no apparent resolution. Thanks for the response.
