08-21-2022
08:56
15:33
LizzyFitbit
08-21-2022
08:56
15:33
LizzyFitbit
I had to adjust all my applications to work with the Sense. I connected the Bluetooth and Local Network to on. Is this the reason it doubled my steps yesterday?
iPhone fixed:
1.) I had to go to iPhone 13 setting.
2) Go down to the Fitbit icon: Turn off Local Network Wi-Fi setting so program would not double the steps for my WW Weightwatchers application.
Thank you.
08-22-2022
15:46
04:53
08-22-2022
15:46
04:53
Hi there, @Susie-D.
Thanks for letting me know the Bluetooth and Wi-Fi is connected. This is odd as your Sense shouldn't double your steps when having those settings turned on. To look into this, may I know if by updating your applications you mean the Fitbit app? Or do you refer to the apps installed on your Sense?
Because your post didn't mention, I'd recommend the following steps:
Best AnswerIn August I received updates from Apple for Iphone, Fibit for tracker, and WW updated their application. I have checked setting for Iphone since some settings changed in the update. I checked the Fiting settings to make the Blue Tooth and Wify were not turned off. I will try your approach and keep monitoring my steps daily. Thank you.
08-23-2022
12:37
05:09
08-23-2022
12:37
05:09
Hi there, @Susie-D.
You're welcome, and thanks to you for getting back with the requested information. Please give a try to the steps shared above whenever you have time and don't hesitate to let me know if the issue persists.
Best AnsweriPhone fixed:
Thank you.
08-29-2022
15:57
05:09
08-29-2022
15:57
05:09
Hi there, @Susie-D.
I'm glad you sorted this out and thanks for sharing the steps that worked for you. That's a great tip and I'll mark your post as the Best Answer so we can help other members experiencing similar issues.
If you have time, check out our Health & Wellness board where you can share your experiences, meet people and create new topics. Keep up the super stepping! 😎
