03-29-2022 14:53
03-29-2022 14:53
My Sense is often draining from 25-30% to zero in less than a night. I can tell from when my phone and email receive low battery indications to when the Sense stops recording my sleep. My firmware is up to date (version 44.128.6.12). I bought the device new in January 2022. Any suggestions? Thanks!
Best Answer03-29-2022 19:20
03-29-2022 19:20
@Hornet1455 Welcome to the Fitbit community.
Pretty sure you have snore and noise detection on which does warn of the extra battery usage when on. Follow the guide that @Clove6060 for other tips.
Best Answer03-29-2022 15:12
03-29-2022 15:12
Here are some good suggestions!
03-29-2022 19:20
03-29-2022 19:20
Best Answer03-30-2022 00:04 - edited 03-30-2022 00:05
@Clove6060 Thanks for the tips!
@eezeepee Thanks for the welcome! Yes, I do have snore detection enabled. Does this mean 30% battery drain in 5-6 hours -- on a device supposedly designed to run six days -- is a feature, not a bug?
Best Answer03-30-2022 04:03
03-30-2022 04:03
My battery will drain overnight with snore detect on 23%. Without snore detect on my battery depletes 20% in 24 hrs. Battery usage depends on settings and features enabled. I saw that caveat somewhere in Fitbit literature.
Best Answer03-30-2022 07:48
03-30-2022 07:48
@Hornet1455 Keep in mind most battery claims for devices are in ideal conditions and are more of a maximum battery life rather than an average.
I can get 4 whole days with these settings:
Brightness dim, screen wake motion and button, always-on display off, snore & noise detection off, SpO2 on.
The biggest battery drainers, especially overnight, are the snore & noise detection and SpO2, but more so the snore & noise. With it on, I lose around 20% over 7 hours of sleep. With that option off, I only lose around 6-8% over 7 hours of sleep. I had it on for over a week and I don't snore and noise is minimal so it wasn't worth the drain. If I turned off SpO2 I would definitely get 5-6 days. I keep that on because it's part of the health metrics.
