05-16-2024 12:16
05-16-2024 12:16
Over the past 4 days the temp reading on my Sense has been fluctuating several times a day between celsius and fahrenheit. The units in the app are set to fahrenheit. The phone and Fitbit are paired and connected. All other readings on the FB (steps, stairs, heart rate, etc.) are correct. I have unpaired and paired again. I have turned the FB off and back on (several times). I have deleted the app from my phone and reinstalled (and paired and connected again). I'm using the AccuWeather app. The FB says that weather is updating regularly but it will still show C temps. The phone is a Samsung Galaxy S9+ (Android). Has anyone else had this problem? Any suggestions? Thanks.
05-16-2024 20:46
05-16-2024 20:46
Hi @Timberlake - there are 2 temperature settings, one for the Fitbit App and one for weather.
In the Gallery tile, select Weather and Settings and set Fahrenheit there as well as the Fitbit App, App settings.
Best Answer05-16-2024 20:46
05-16-2024 20:46
Best Answer05-16-2024 21:19
05-16-2024 21:19
