07-05-2024
13:50
17:19
07-05-2024
13:50
17:19
Hi I have 2 vertical white bright lines running down left side of my Sense. One slightly wider than the other
I would appreciate a fix
Thanks
Dean
Best Answer07-05-2024 17:21
07-05-2024 17:21
Hi there, @deanjane. It's nice to see you around the Fitbit Community Forums. I'm sorry to hear that the screen of your Sense has developed vertical lines. I will do my best to help you with this.
If you haven't done so yet, please try the steps below:
If the above doesn't work, please restart your Fitbit device as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best Answer07-07-2024 00:55
07-07-2024 00:55
Best Answer07-08-2024 03:21 - edited 07-08-2024 03:21
@deanjane I'm sorry to hear that the issue persists. Since you tried the steps I recommended here and they didnt work, you have a Sense and report experiencing a corrupted screen, I need additional information from you that would best be shared privately. I’m sharing a link to a form for you to fill out so we can look into this further.
This form is only meant for you to use, so let me know once you’re done. Click here to get access to it.
Best Answer07-10-2024 07:40
07-10-2024 07:40
Sorry for delay
For some reason I didn't get your reply.
I have done as you asked and filled in the form. What will happen next and when?
Thanks for your help
Dean
Best Answer07-10-2024 07:42
07-10-2024 07:42
Also this post is coming up as answered. It had not been answered how do i change this. I do need help
Best Answer07-14-2024 23:22
07-14-2024 23:22
