08-07-2024
12:03
09:34
08-07-2024
12:03
09:34
My sense isn’t showing stats (pace, HR, steps, etc) in the centre of the screen when using the exercise app. Where the stats usually show in the middle, it's now a blank circle. I've tried restarting my Fitbit watch. I saw a post from a couple of years ago where someone had a similar problem but it wasn't resolved. Thanks.
Best Answer08-09-2024 09:35 - edited 08-09-2024 09:37
Hi there, @Wilesy. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention, for the troubleshooting steps you've tried, and for the image attached. I'm sorry to hear that your Sense is no longer showing your stats in the centre of the screen. I will do my best to help you with this!
Did you change the clock face on your Sense recently? If you haven't done so yet, please try the steps below:
If the above doesn't work, please restart your Fitbit device once again as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best Answer08-11-2024 11:05
08-11-2024 11:05
Hi @MarreFitbit .Thanks for your response. I've tried what you suggested but unfortunately it hasn't worked. I've since noticed that the problem is not just in exercise mode, it's also missing the info on the display when I tap the screen to cycle through the stats (see attached image).
Best Answer08-12-2024 08:32
08-12-2024 08:32
@Wilesy Thanks for following the steps I recommended and for the image attached.
Since all the steps you tried didn't work, you have a Sense and report it's not showing your data on the screen, I need additional information from you that would best be shared privately. I’m sharing a link to a form for you to fill out so we can look into this further.
This form is only meant for you to use, so let me know once you’re done. Click here to get access to it.
Best Answer08-12-2024 11:59
08-12-2024 11:59
Thanks @MarreFitbit - I have now completed the form in the link as requested.
