07-05-2022
09:59
07:07
07-05-2022
09:59
07:07
Hi, My average calories was significantly higher than normal. How can I manually change this? Thanks
Best Answer07-05-2022 10:03
07-05-2022 10:03
Check your weight.
Best Answer07-05-2022 10:19
07-05-2022 10:19
More specifically on the Fitbit app my average calories was 5000 yesterday and 4500 the day prior. It should be 2-2500 calories burned per day.
Best Answer07-05-2022 10:27
07-05-2022 10:27
@Mikesblack wrote:More specifically on the Fitbit app my average calories was 5000 yesterday and 4500 the day prior. It should be 2-2500 calories burned per day.
And did you check your weight?
