12-29-2021 08:38
12-29-2021 08:38
Hi all,
Desperately need help.
Bought a Sense and setup and all worked well. 3 weeks on, first issue not synching message on app "no internet connection fix it "
Internet was OK and working for all other apps.
I followed advice on other posts i.e
Turned Bluetooth off
Uninstalled Fitbit app
Stopped Sense
Restarted phone
Started Bluetooth
Re-installed Fitbit app
Switched Bluetooth on
From app-
Set-up device
Selected Sense
Clicked setup
Message on app "trouble connecting to network"
Samsung Galaxy S7 Edge - all other apps OK and network active.
I tried to setup via Windows 10 on laptop, using same network, and device setup OK.
Removed everything from Windows and went through setup on Fitbit app and got same issue "trouble connecting to network"
All software up to date, watch fully charged.
09:19
11:48
12-29-2021
09:19
11:48
Hi @Thequizman - thanks for the very precise steps taken. Only thing missing is the Fitbit App version and Watch firmware version.
Things to look for are VPN connections and security software on the phone, which let other apps work but could be a problem for the Fitbit app.
That said a few others have mentioned the same issue so it could always be a bug.
You can try with Data turned off and Wifi on, or vica versa, but in all probability your phone isn't allowing access to the Fitbit servers.
To simplify testing you can try clearing the cache and force stopping the Fitbit App between tests, and even logout and login.
In Android phone Settings * Apps Fitbit Storage - clear cache [not data] Force Fitbit Stop [though it doesn't seem to fully] Go back in to the Fitbit app
*Quick Shortcut: Press and hold the Fitbit launch icon, then App info [on some phones] |
Best Answer12-29-2021 10:51
12-29-2021 10:51
10:59
11:49
12-29-2021
10:59
11:49
@Thequizman - looks like you still have some security software blocking the connection or the VPN restarted.
At least progress, thanks for the feedback and information.
Interesting you have Fitbit App 3.53 for Android 8.
Only 3.52 available for Android 10.
12-29-2021 16:18
12-29-2021 16:18
I rechecked versions and they are as published.
VPN hasn't restarted and internet security has Fitbit as allowed.
Something I noticed on Sense settings that states set up wifi, so when I looked at this, my network is listed and when I select, it shows as Connected! Not sure what the ! Means but when I try to sink it still has no internet and when I check settings again, network is not connected ans states set up wifi.
12-29-2021
19:09
11:48
12-29-2021
19:09
11:48
@Thequizman - WiFi on the watch seems configured ok if you see it listed.
Watch WiFi is only normally used and active for firmware updates, the principal communication for syncing with the phone is only done via Bluetooth.
A phone internet connection free of security software blocking on the phone is required for successful syncing and operations with the Fitbit servers, otherwise the information from the watch cannot be uploaded to the servers and the syncing may not complete.
Best Answer12-30-2021 03:20
12-30-2021 03:20
Resolved....
It appears to have been the VPN after all.
Although I stopped the VPN, it still wouldn't connect to the internet I had to uninstall it and now everything is working fine.
Thanks for your help.
12-30-2021 04:03
12-30-2021 04:03
@Thequizman - thanks for the report back, it will surely help others.
