02-19-2021
09:37
09:58
LizzyFitbit
02-19-2021
09:37
09:58
LizzyFitbit
I have the fitbit sense and have managed to click on a clock face that I do not want. I now have a message on my watch to tell me to go to a website to enter a code, but the site does not seem to work and I can not get the message off my screen.
I have left my watch to go flat and it is still there. I can not do anything with my very expensive watch. Please help
02-19-2021 13:44
02-19-2021 13:44
Go into the app and select another watch face.
02-19-2021 14:31
02-19-2021 14:31
Thanks for the reply, I had not been able to come out of the screen. Think it may have frozen, all sorted now. Thanks again for response
08-17-2022 02:58
08-17-2022 02:58
Hi.i need help bout my fitbit watch it keeps coming up n staying on my watch to vist kzlio with a code how do I get rid of it plz xx
08-17-2022 03:48 - edited 08-17-2022 03:49
Hi, @Sammi04, welcome to the community, select a different clock screen (made by Fitbit - not someone else) in the Fitbit app. From the today screen in the Fitbit app on your phone touch your icon in the top left corner>"Sense" tile>gallery>clocks>by Fitbit and set up a new clock face. If necessary restart your "Sense" by squeezing the side button for about 20 seconds and releasing it when the logo appears. After about 35 seconds you should be back to normal. Incidentally which clock face were you trying to install?
I hope this helps but please post here again if you are still stuck.
Cheers
Gr4ndp4 | UK
09-04-2022 14:56
09-04-2022 14:56
No luck getting rid of this off of my watch either. Can't get in to settings either to try to change anything!
Best Answer09-04-2022 15:52
09-04-2022 15:52
Hello @Stuntwoman
Try to change your clock face by going through the Fitbit app…not using the Fitbit watch. Open your Fitbit App, tap your profile picture then scroll down and tap Sense. Next tap Gallery. Change your clock face here. Preferably change your clock face to either the original clock face or any other clock face made my Fitbit.
If you need further help look here: https://help.fitbit.com/articles/en_US/Help_article/2311.htm
