10-31-2021
07:55
11:18
LizzyFitbit
10-31-2021
07:55
11:18
LizzyFitbit
Hi lost icons on watch carried out reset and attempted to set watch up again set up goes to 100% then looses connection with watch. I have tried numerous times to reset watch and date up watch but still having the same issue ??? Thanks
11:13
09:57
11-01-2021
11:13
09:57
@Connect61 Welcome to the Community.
Thanks for taking the time to troubleshoot your Sense. I'm sorry you're having this inconvenience and to look into this, may I know the model of your phone? Also, do you see an error message on the Fitbit app?
I understand you've tried some steps, but please give a try to the following in the given order:
Hope this helps.
Best AnswerI have tried all of the steps, updated my phone, updated the app, there is no update available for the Sense. It will pair, work and then lose the pairing shortly afterward. It’s very upsetting since it will not sync and I use the app for monitoring calories in and out daily. The Sense was only purchased in November!
Is there anything else to try?
Yes, I’ve checked everything I can think of. It connects for a while and then disconnects, even with the apps running in the background.
