02-24-2022 09:56
02-24-2022 09:56
Im 72. my sense showed 9989 steps between 3:45 am ridiculous dataand 4:00am.
I called fitbit, i pay for premium. My sense is in pristine condition as a senior who has been under a rock for the pandemic. I wear the fitbit to bed. I was told by the service rep it was probably the wind or the heat or air condition. All absurd. My 75 y o friend had a middle of the night HR spike, followed it through an was found to have Afib. We depend of reliable data at our age. So FYI the wind will give you an extra 9989 steps in 15 minutes per support staff. Absurd.
02-25-2022 03:29
02-25-2022 03:29
Mine has done this twice now...
Messes up all my activity and averages, no way to just delete the hour or anything...
02-25-2022 04:11
02-25-2022 04:11
@Pillywiggen @Kris98 Does this happen regular like a few times a week?
These are my steps from yesterday and today so far:
In just over 8 weeks of use, I have yet to experience a huge step count spike like that overnight. The most I've gotten is still less than 50 steps total while sleeping which is negligible for me.
It's not great that you can't delete those steps but I would restart your Sense to see if they clears things up.
Best Answer02-25-2022 05:47
02-25-2022 05:47
2x this past month, absolutely destroys my average and goals
Best Answer02-25-2022 06:38
02-25-2022 06:38
@Pillywiggen @Kris98 It's not ideal but this other thread appears to have a workaround so that the steps get deleted or not counted.
https://community.fitbit.com/t5/Fitbit-com-Dashboard/How-to-Delete-Steps/td-p/1511807
02-26-2022 12:17
02-26-2022 12:17
I am not as worried about wrong step count as much as I am concerned I will miss data indicative of a health problem due to some "glitch" caused by the "wind" while I am sleeping. That answer was so ridiculous yet disturbing.
Best Answer02-26-2022 12:22
02-26-2022 12:22
This happened 1x to me. I am not worried about the steps as much as health data. I am disturbed fitbit staff say the wind did it. The health data, H R while sleeping, is what cued my husband to a problem. He was aymptomatic for a heart problem and had surgery only weeks after the fitbit HR data in the middle of the night showed something wrong. If he called, rather than take HR data at face value, and they told him it was the wind...... see what I am talking about ?
Best Answer02-26-2022 19:13
02-26-2022 19:13
@Pillywiggen Okay but the steps and heart rate are two different sensors. Are you having any issues with the heart rate monitoring?
Best Answer02-26-2022 20:32
02-26-2022 20:32
Most have been some marathon you where dreaming about.
Best Answer02-26-2022 21:07
02-26-2022 21:07
Best Answer02-27-2022 13:39
02-27-2022 13:39
@Pillywiggen It's not acceptable but it's also not a huge widespread issue. Problems with syncing, connections, or even heart rate monitoring during activities is more common than random thousands of steps from what I've seen here in the Fitbit community or Google searching. My wife was a Fitbit user for several years her Alta, Versa, and Sense never had an issue with thousands of steps over night. And she would definitely let me know if she had that.
Best Answer03-01-2022 10:45 - edited 03-02-2022 05:29
Do you have MobileTrack enabled? If so, disable it. I had a similar issue with MobileTrack enabled where it said I took "12k" steps in as little as 15 minutes while sleeping, then a month or so later it did the same thing while the Sense was charging, recorded "8k" steps. Since disabling it, I haven't had those phantom steps anymore.
03-01-2022 11:05
03-01-2022 11:05
@primortal Good recommendation. Hopefully that's the fix.
