08-26-2024
08:38
08:46
08-26-2024
08:38
08:46
My Fitbit Sense was out of battery and now it's not charging at all. Completely off.
Already cleaned it, try to push long the button. Nothing works.
What can I do?
Hi there, @PedroMiguens. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Sense is still not charging. I understand your concern, I will do my best to help you with this!
Please note that there are some issues that affect this, being which power source is used and how clean the contacts are and how well the charger is seated. Did you clean both? Your device and charger? Confirm that you've tried all tips and recommendations provided here Why isn't my Fitbit device's battery charging?
Please make sure your Sense is receiving good power source, please find below some tips to best charge Fitbit devices:
For charging purposes, your charging cable or your base station can be plugged into any USB power source, including but not limited to:
Also keep in mind that a Fitbit might not seem to be charging when actually the issue is that it has become unresponsive (this can happen if the battery has been allowed to discharge completely). I would suggest putting it on to charge on a charging wire and outlet known to be working. Leave it on the charger for a good two hours, even if it doesn’t seem to be charging.
Best AnswerThank you for the help
@PedroMiguens You're very welcome!
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
