10-13-2020 13:32
10-13-2020 13:32
Most runs I go for is missing the start, I am manually starting the run and check my pace regularly so I can see its working. But when I get home and sync it to my phone the data from start is often missing. Is this a setting that needs changed or a bug?
Does the "do not track runs longer than x minutes" only track the end? How does this function work?
Best Answer10-13-2020 14:05
10-13-2020 14:05
Make sure the GPS is connected when you start running.
Best Answer10-13-2020 14:25
10-13-2020 14:25
Will make sure its connected next time
