06-10-2025
09:25
20:32
ManuFitbit
06-10-2025
09:25
20:32
ManuFitbit
My Sense is just not turning on. It is a blank black screen and even the lights on the bottom of the watch do not come on. It will not respond to attempts to reset it(holding side button for a while, 10 to 30s) and has been on the charger overnight and for a couple additional hours.
Yesterday, it had low battery when I was using it while swimming. It suddenly turned blank(the battery was around 12%) and did not respond when I put it on charge, but I assumed it just died.
Today I tried to turn it on but it did not respond. I used a lightly damp towel to clean the contact points on the watch and then allowed it to charge for another hour before trying to reset. I've tried to reset it a few times within the past hour. I've held the button for as long as 2 minutes. Still blank black screen with no lights. What should I do?
Moderator edit: clarified subject.
Best Answer06-10-2025 20:31
06-10-2025 20:31
Welcome to the community forums @omeraw.
Thank you for providing the details regarding this difficulty that you are experiencing with your Sense. Thank you for trying to fix it on your own.
Please make sure to follow all the steps listed in this help article: Why isn't my Fitbit device's battery charging?
06-11-2025 14:24
06-11-2025 14:24
I tried plugging it into a new outlet and it sort of responded. When I have it plugged in, it vibrates once. Then if I hold it while it's plugged in, it vibrates another time. But it doesn't vibrate any more if I hold it longer after that. And it still has had a blank black screen through all of this. Any ideas?
Best Answer06-20-2025 20:26
06-20-2025 20:26
It seems like I too am in the just died category, which is frighteningly common on these forums. Can't even figure out a way to get to support by chat anymore. Just another example of nobody cares about their products or those who buy them.
