04-20-2022 06:10
04-20-2022 06:10
I live in a single story home in flat Florida. The last week I am showing 60-95 floors climbed.
How can I get this corrected?
04-20-2022 07:10
04-20-2022 07:10
This was happening two weeks ago and I just ignored it, now it is under counting my steps. And needs to be charged constantly. 😞 No solution
Best Answer04-20-2022 08:54
04-20-2022 08:54
Hi @hsinger2384 - if you look in the forums you will see it's a common problem. There is no fix.
If you are interested in how your watch pressure sensor is behaving or whether you can get a more accurate floor count, you can verify you don't have a watch problem by using the SimpleFloors app.
The App shows how your watch is affected by environmental issues such as, going room to room, upstairs/downstairs, inside to outside, changes in temperature, etc.
If you have Shutdown the watch and restarted it and the problem remains it is a firmware issue.
This App is only meant for checking purposes as it uses the battery a lot, but at least it will give you an idea if your watch is fine or if it is some other issue.
Best Answer04-20-2022 08:58
04-20-2022 08:58
Hi @hsinger2384 - try Shutdown from the Watch Settings menu, wait at least 10 seconds before placing on the charger to restart and charge it.
