12-15-2020 06:48
12-15-2020 06:48
Hi,
I followed all procedures correctly and connected the Sense to my phone for the first time Yesterday. Since then I've had to reconnect the sense 3 times. I have to "trashcan" the sense through the app and go through the complete process again. I've tried every combination of Bluetooth on/off, forget/connect, app (not really anything I can do in there other than spam sync, which continuously fails)
What's going on Fitbit. Seems like a very rudimentary issue here.
Fitbit, fixit
Best Answer12-15-2020 06:49
12-15-2020 06:49
I've used "setup" device to reconnect it as well, either way, absurd process to go through multiple times a day. One moment the watch takes calls/texts, the next it doesn't, it needs to maintain a connection
Best Answer12-15-2020 11:19
12-15-2020 11:19
Not sure what the problem is @Tomhhqs23
Why does it require setting up the tracker to your Fitbit account? Or What is not happening that you feel you have to do this?
12-15-2020 12:45
12-15-2020 12:45
Mine done that too at first but after three factory resets mine is staying connected. I use it with a Pixel 4 XL. The last time mine lost connection with my 4 XL out of nowhere. Wouldn't sync and wouldn't pair. I done a factory reset, the third one since owning the Sense and so far it's been fine. Staying connected with Bluetooth and no syncing issues. Try a factory reset of the watch.
12-16-2020 08:39
12-16-2020 08:39
Connectivity stops to the phone
It'll say last refreshed [x] and the number won't increase, I've had x go up to 3 hours. Stats won't pull over to phone, calls and messages won't send over to watch . I'll press refresh to manually /force refresh and it won't.
Best Answer12-16-2020 12:10
12-16-2020 12:10
Can not keep mine paired at all either. Sense Control just spins while my phone shows paired. Paired fine this morning for about an hour then kicked off. Happened multiple times yesterday, first day with the watch.
Best Answer12-16-2020 17:41
12-16-2020 17:41
Try these steps next time.
Not knowing what phone. Pairing is simply telling the phone that the Fitbit is a trusted device. And when communication between the two is needed, to let them communicate.
To unpair the user would open the phones Bluetooth and remove the tracker. This is one of the steps that have been found use full when the tracker will not sync.
The app does the actual pair with the phone.
Best Answer12-16-2020 17:45
12-16-2020 17:45
I am using an Android.
This is part of what I did to get it working again. The issue is that I've had to complete the thorough reconnection/device add process 3 times in 2 day (3 being on the first day). No issues yet today, I am guessing the watch was just having a difficult time b/c it was performing initial updates.
Thanks for offering your assistance 🙂
Tom
Best Answer12-16-2020 19:24
12-16-2020 19:24
Sending my Sense back, apparently it's not compatible with all Androids ( would have been good to know). Using a Note10+, Android 10 Os.
Best Answer12-16-2020 21:38
12-16-2020 21:38
I've had the Sense since it first came out and also use a Note 10+. Up until this past weekend when my phone went thru an update, it worked great. Don't give up yet, love this fitbit and its worth it!!!! This issue will get worked out.....
