06-01-2022 18:58
06-01-2022 18:58
Every once in a while (every few days?) the watch face I’m using will revert back to its original settings. (I change the view settings to steps, floors, active minutes and it will revert back to steps, Miles, and calories burned.)
At the same time, it also reverts back to Celsius units in the weather app.
very frustrating to set it all up again just for it to revert back in a day or so.
06-01-2022 19:50
06-01-2022 19:50
Hi @JanineI - this could be an issue with the clock face you have chosen.
It may not remember the settings you have chosen.
To verify, when it is as you want, swipe the face to the left and click on settings, then press the button to return to the clock face and see if the settings have changed.
06-07-2022 04:40
06-07-2022 04:40
06-09-2022 05:08
06-09-2022 05:08
Still having same issue. I have tried:
Not sure what else to try.
06-09-2022
05:17
11:02
06-09-2022
05:17
11:02
@JanineI - well you have pretty much tried everything.
if you are on Android try logout of the app, clearing the storage cache and force stop the app, then change the weather temperature units. And restar phone and sync.
If that doesn't work contact Fitbit, via the app, click profile photo, Help & support, Contact Customer support
