12-02-2023
11:15
07:35
12-02-2023
11:15
07:35
This just happened and i don’t know what to do 😞
Best AnswerThe seals degrade over time, there are a few ways to fix, you can use an epoxy to seal it back up, remove the old seal, search the forum there are many tips.
If you have a heat gun you can attempt to heat up the seal press the screen back into the hot seal and it might reseal it.
If you are uncomfortable find a repair shop that will do it for you. Just make sure all traces of moisture are removed before you get the screen re attached
