06-11-2024
02:24
07:44
06-11-2024
02:24
07:44
Hi
Am using my sense since December 2020 without much issues (strap changed twice-that’s the only maintenance so far)
Today morning, while working on my laptop, the Sense display popped out all of a sudden! Searched the forum and found a number of threads with similar complaints- all closed ones- on the issue.
Fix with some glue seems to be the solution but for a smartwatch of this cost should be built with some better quality!
Hi @Sagir - as it's out of warranty that seems like a good solution but the seals can fail over time depending on use and exposure on some watches. Avoid getting it wet and monitor battery life just in case the battery has swollen.
If it gets hot when charging stop immediately and don't wear it.
