04-27-2025
04:04
09:34
04-27-2025
04:04
09:34
Fitbit sense should allow bluetooth to be switched off . Help minimise emf radiation specially during sleep tracking
@Indraneel , A warm welcome to the Community! Thank you for your feedback.
I invite you to post your request as a suggestion in our Product Feedback board in the Fitbit Community. This is the best place to raise new ideas and comment on other members' suggestions.
If a similar suggestion has already been made by another member of the community, you can vote for their suggestion and add your comments.
Hi @Indraneel - as indicated the product feedback forum is the place to vote for this option that is not available on any Fitbit smart watch.
Turning off the phone's Bluetooth will have an effect as there can be no communication and can reduce any radio waves to virtually nothing.
In addition the strength of the signal is very feeble anyway which is why Bluetooth is used so the battery doesn't drain too quickly under normal Bluetooth usage.
