05-30-2022
08:17
11:38
LizzyFitbit
05-30-2022
08:17
11:38
LizzyFitbit
Hi again! So I received the replacement Sense. This one alerting me to text messages received - but it does not send the text, instead it seems to show the exact same calendar invite reminder every time I receive a text message. Do you know how I can "fix" that? It's really strange but I'm wondering if there might be a setting I'm not seeing, so thought I would ask. Thank you in advance for any tips.
Moderator Edit: Clarified subject and updated label
Best Answer05-30-2022 11:27
05-30-2022 11:27
Hi @tomperse, May I suggest you check your phone app settings. From the "Today" screen touch your icon in the top left corner>Sense tile>notifications. Check the slider on the top right is "on" (to the right), touch text messages>select your preferred app>return to notifications repeat for "Calendar Events" and Emails> App notifications> ensure Fitbit is checked. Return to"Today" screen & sync. These settings should give you incoming messages from your preferred app.
Let us know how you get on.
Cheers
Gr4ndp4 | UK
Best Answer06-03-2022 05:24
06-03-2022 05:24
Nothing seems to rectify this glitch - what is so very odd is it sends the exact same calendar invite everytime I receive a text. Sometthing is causing the Sense to think every text is this single calendar invite. I have tried many attempts and fixes - alas nothing has worked.
Best Answer06-03-2022 07:28
06-03-2022 07:28
Hi, @tomperse absent progress I suggest you talk to "Customer Support" here, I recommend you use the chat facility or phone for a prompt response. Your problem is unusual (I've not seen it mentioned before) I suggest you get all your ducks in a row before contacting them, note the make & model of the phone and the O/S you are on. Also, note the steps you've taken to try and resolve the problem.
Good fortune.
Cheers
Gr4ndp4 | UK
07-07-2022 21:56
07-07-2022 21:56
This is happening to me too. Did you manage to fix it?
Best Answer07-08-2022 03:06
07-08-2022 03:06
Hi, @Sdun4, have you tried the suggestions I put forward in my earlier posts? If so what was the result.?
Let us know.
Cheers
Gr4ndp4 | UK
Best Answer07-08-2022 08:37
07-08-2022 08:37
Best Answer07-08-2022 08:38
07-08-2022 08:38
