10-05-2020
05:43
17:29
LizzyFitbit
10-05-2020
05:43
17:29
LizzyFitbit
I have been wearing my sense for a week now and the skin temperature feature is in the negatives. Last night was -1.1 degrees and the night before that was -1.9 degrees. Is there a problem with my device?
Moderator Edit: Clarified subject and updated label
05-19-2022 13:55
05-19-2022 13:55
thank you for the very clear and definite answer. Why do they keep the absolute temp hidden?
05-30-2022 23:48
05-30-2022 23:48
Hi Drew. Do you know how I find out my actual skin temperature during sleep, to be able to make better use of this feature? Standard is anywhere around 33degC I’ve read, but I would like to know my actual skin temperature if possible.
Many thanks.
05-31-2022
00:17
03:46
05-31-2022
00:17
03:46
Hi @LesleyE79 - you can't get actual skin temperature.
What shows in the app is only relative night skin temperature from a baseline re-evaluated over days.
The actual skin temperature is so easily varied by environmental conditions that an average is the most meaningful.
That said it is measured every minute for the 24 hours. You can export your full archive from the dashboard to get the readings but that's probably not what you want to do.
Currently there is no possibility to get an instant reading for a quick indication.
05-31-2022 00:21
05-31-2022 00:21
05-31-2022 01:10
05-31-2022 01:10
What is still unknown is the difference between the specific sensor installed on Sense and the generic one of the other trackers.
06-18-2022 16:21
06-18-2022 16:21
When we'll, your body is in a normal thermoregulation pattern from core (brain and organs) to skin. Core&skin relatively track.
Fever is special immune response. For cold blooded animals feeling sick, they will seek out a very warm place and induce their own fever. But warm blooded animals can generate their own heat. To do so, the hypothalamus detects the cellular ravages of infection, then secrete hormones to increase heartrate, vasoconstrict the skin then vasodilate our our delicate core.
Get this: the fitbit has an incredible tell that we are fever infected. That tell is that your skin temperature drops while your core temperature increases. Yes skin temperature goes cold in the fevered state. Imagine that.
And while that may be unbelievable, ask yourself why when you're suffering a fever, you shiver. QED.
06-18-2022 20:50
06-18-2022 20:50
07-23-2022 09:29
07-23-2022 09:29
It doesn't matter if it's instant or not, there is no point in hiding what the baseline temperature actually is and the variation data is useless without it.
08-22-2022 09:58
08-22-2022 09:58
I can't find how to download SPO2, Temp and HR. Will the API do that?
08-22-2022 10:19
08-22-2022 10:19
Hi @Rikheller - it is done automatically when you sync the watch with the Fitbit App.
02-18-2023 07:56
02-18-2023 07:56
Hi,
Dod you manage to find a way to do this?
02-18-2023 08:04
02-18-2023 08:04
No it’s a mine field
02-18-2023
08:04
16:32
02-18-2023
08:04
16:32
02-18-2023 08:25
02-18-2023 08:25
Unfortunately it only shows the last 7 days
02-18-2023 08:27
02-18-2023 09:00
02-18-2023 09:00
Thank you. You gave a much better answer than Fitbits support! I shan’t be buying premium until they sort out the food inaccuracies, but that’s really useful to know thank you.
03-26-2023 21:11
03-26-2023 21:11
But where do they say what your baseline is so that u can upstand those results when they vari from the baseline. From what I can see it shows me 0.8 above baseline but I don't know what the baseline is so that means nothing to me
