Everything else on my sense works great but the skin temperature, sometimes it works sometimes it doesn’t I’ve reset the sense the sense is updated to the latest it just doesn’t work, it will give me a skin temperature for a couple nights then it will go for a week and not give anything I’m about to delete it off, so if someone has an idea that would be great
Hi, @David211, welcome to the community, may I draw your attention to this article How can Fitbit help me track my temperature? which contains guidance and advice. Please post here again if you are not able to make progress.
Cheers
Gr4ndp4 | UK
06:02
07:38
08-21-2021
06:02
07:38
Hello @David211. Welcome to the community forums. @Gr4ndp4 Nice to see you around and thanks for your input.
Thank you very much for the detailed information and for the steps you've followed. At this time, I'd like to let you know that if you don't see health metrics data, I'd recommend taking into consideration the following tips:
For more information, please check: What should I know about health metrics in the Fitbit app?
Best AnswerYeah I’ve tried everything, the only time I get a response from it is when I reset the sense, it just gets a little annoying to have to reset it every day, so I’m just gonna delete it completely, I think Fitbit needs to improve on that a little more
Hi, @David211, It's a pity you are still experiencing a problem with the skin temperature data stream. May I suggest you review the @WilsonFitbit post above, In order to establish the data base line you need to wear the "Sense" for at least 3 days and nights.
I hope this is helpful.
Cheers
Gr4ndp4 | UK
