01-06-2022
17:55
15:45
LizzyFitbit
01-06-2022
17:55
15:45
LizzyFitbit
I have the premium package and was able to get a snore report one time. I have not gotten one since. When I try and select the snore detect it does not respond. The advanced sleep analytics works. I have detect snoring enabled. I have the microphone enabled. I have synced using my iPhone and iPad with same result.
01-10-2022
15:56
02:45
01-10-2022
15:56
02:45
Welcome to the Community, @Jocon231.
Thanks for confirming that you have an active Premium subscription, and making sure the right settings are enabled. I'm glad you're getting sleep stages and just to double check, please try finding your snore reports one more time with the following steps:
If there is nothing displayed on these sections of the Fitbit app, please provide me with your phone's model and attach a screenshot showing what is displayed instead. These details will help me to further investigate on my end.
Thank you for reaching out. I have an IPhone SE and a IPad 7th gen which shows the same issue. When I try to upload the images I get a response that I do not have permission to upload images.
01-17-2022
17:52
17:11
01-17-2022
17:52
17:11
Hi there, @Jocon231.
You're welcome, thanks to you for getting back with the requested information and your efforts while trying to upload a screenshot. I'm sorry the same keeps happening and let's try reconnecting your watch to the Fitbit app to see if that helps:
Hello,
That seems to have worked. I have gotten a couple of snore reports, missed a couple of days, could be noise environment or just the mic not picking it up.
Thank you for your assistance!
01-27-2022
16:37
03:37
01-27-2022
16:37
03:37
@Jocon231 It's good to see you here in the forums.
You're very welcome! I'm glad this got sorted out thanks for trying the steps suggested above. About your other question, let's restart your Sense to refresh its performance, turn off and back on the microphone on the Settings app of your watch, as well as Snore Detect on the Fitbit app. Once this is done, try wearing it to sleep and sync as soon as you wake up to find your reports.
Best AnswerHi
My Samsung S10 last displayed a snore report on 24rd June. I am a Premium member. My microphone is on. I make sure that the watch has over 40% battery left at night. I have followed all the advice & suggestions but to no avail. I am assuming that this is a bug & that Fitbit will eventually fix it. It would be good to get feedback/confirmation of this from a Fitbit moderator though.
I also have everything right with the settings, but all I get is Time Asleep, Sleep Schedule and Sleep Quality on the App for Versa 3. No snore report
Best AnswerMine just says it couldnt collect enough data. & to wear my watch at night. I've also tried wearing the band tighter & looser. I've come to the conclusion that it's a software error - but I will cancel my premium subscription before the free period ends.
Best AnswerSnore Report is back working again but only after I set up voice control via Google. Must be something to do with microphone access.
Best AnswerThanks. Mine is sporadically working now, but doesn’t seem to be that accurate and therefore not all that helpful
Best AnswerTo find your snore report, click on the sleep tile, then click on the days sleep you want to see the snore report for, then click on restoration, scroll down to snore and noise, where you will find “view snore report”.
Best AnswerHi…I’ve had a premium membership and was viewing the snore report daily. A few days ago, the icons and data just aren’t showing up at all…I’ve deleted the app….reloaded…restarted my phone….so many suggestions and nothing has changed….it’s as if the app is completely different and just doesn’t have the capability anymore.
please advise.
i have screen shots I can email directly
thank you
Welcome to the forums, @Aulton.
I'm glad you sorted this out, and thanks for sharing the steps that worked for you. I'm sure other members will find your post very helpful. Let me invite you to visit our Health & Wellness board where you can make new friends and find inspiring stories. Have a good day!
