03-23-2022
07:21
14:44
LizzyFitbit
03-23-2022
07:21
14:44
LizzyFitbit
My Sense stopped recording my temperature two nights in a row. I’ve restarted it, and checked to see if there was an update, but everything is up to date. I’m not sure why it suddenly stopped recording. Any advice?
Moderator Edit: Clarified subject and updated label
03-26-2022 06:02
03-26-2022 06:02
Seems to be working again.
Tuesday was the last day it registrered, and now (Saturday) it shows skin temperature again. It has also retrospectively added the Friday measurement.
Wednesday and Thursday are still missing.
03-26-2022 06:11
03-26-2022 06:11
Same here. Sync'd this morning and skin temp is now showing for Friday and today. Other days still missing but am glad it's working again.
03-26-2022 07:12 - edited 03-26-2022 07:13
Back here also, Sweden. It stopped working Tuesday, 22nd, like for most people.
Readings for Tue-Sat have been added even though they are a bit weird, -1.1 to -1.4 Celsius below baseline (manual scans are normal). But readings are at least back. 👍
03-26-2022 07:14
03-26-2022 07:14
Mine showed up today as well
03-26-2022 07:24
03-26-2022 07:24
How are you using it for ttc? I’v been tracking ovulation for 9 cycles with LH tests and haven’t noticed anything consistent with my fitbit temps, temps are all over the place around ovulation.
03-26-2022 07:24
03-26-2022 07:24
Just replaced my ionic with sense Monday. The ionic was solid and never seemed to fail producing stats. The sense stopped producing stats for skin temp on 3/23/2022, and today blood oxygenation. I'm also suspect of the heart rate during exercise. Seems low and inaccurate. How can the software be that much different from the ionic. Thinking I would like to go back to ionic and return this sense, which does not seem to be sensing things too well.
03-26-2022 10:17
03-26-2022 10:17
Thank you fitbit for fixing the temperature! Mine is working today again.
03-26-2022 10:56
03-26-2022 10:56
Mine starting working again this morning. Thanks for getting that fixed.
03-26-2022 15:09
03-26-2022 15:09
03-26-2022 15:52
03-26-2022 15:52
Mine started working again today, but no data for Tuesday thru Saturday. FitBit used to be good… then Google!
03-26-2022 17:08
03-26-2022 17:08
Got my temperatures to show except for March 23rd.
03-26-2022 17:32
03-26-2022 17:32
My temp readings are back but my readiness score is still not showing. Not that it was ever very accurate anyway
03-26-2022 17:45
03-26-2022 17:45
03-27-2022 07:45
03-27-2022 07:45
Update - my skin temp data back since March 26, 2022. Thanks FitBit team.
03-27-2022 12:08 - edited 03-27-2022 12:11
Hi everyone.
Thanks for your continued reports and feedback, as well as the steps tried on your own. While I'm glad some of you're getting the skin temperature correctly, I'm sorry this isn't the case for others. Let me share that our team is aware of this situation and they're working to get this fixed soon. Your patience is truly appreciated and rest assured I'll keep them informed of the impact to you and other members. Once I have more details, I'll update this thread.
By the way, I've moved some of your posts to keep the forums organized.
03-27-2022 13:09
03-27-2022 13:09
03-27-2022 16:29 - edited 03-27-2022 16:30
I've been a fitbit customer for almost 11 years, but this latest issue with the temperature thing had me really paying attention to the other metrics. My readiness score has been lower than I would expect (started around the same time temperature stopped and even though that's back, my score still seemed low today) and my heart rate while working out is definitely lower than it should be (by 20-30bpm-again started around the temperature issue but continued today). I'm not having the same issue as Dogmum, but if this continues, I really overpaid for a watch....
03-27-2022 16:56
03-27-2022 16:56
Yes my sleep has not worked, my temperature doesn't work, and if I can pair my heart rate to what it is at the gym on the machine while I'm working it is way off and then it'll be on and then it'll be off. Think I'm going to check out the Galaxy watch though I just got this one and it hurts that my daughter got it for me for Christmas.
03-27-2022 22:30
03-27-2022 22:30
Now that Temperature is working, breathing rate decided to stop working, not had reading for the past 2 days now. Anyone?
03-27-2022 22:47
03-27-2022 22:47
They may have been trying to fix the case when your reading was +/- 0 showing nothing in the graph - it now shows a faint line which is better and seems to be working still.
