07-01-2023
07:56
09:21
07-01-2023
07:56
09:21
My sense stop counting the floors I climbed. It had been working fine until the last two weeks. I did a soft reset and still not working. Any ideas.
Moderator edit: clarified subject.
Hi @PlutoMath - the pressure sensor may have failed or possibly the clock face has a fault.
To check the latter open the Today app on the watch, if it too has no floors there is an issue.
It can sometimes be the tiny holes on the watch at the back have got blocked. Cleaning can be difficult as poking things in the holes can damage the watch mechanisms.
Note: floors is only indicative as it doesn't affect other measurements.
@PlutoMath - if you want check the pressure sensor to see if it iworking try the free SimpleFloors app - it was made for an earlier firmware but should still be useful.
