11-07-2024
14:22
06:54
ManuFitbit
11-07-2024
14:22
06:54
ManuFitbit
My Fitbit sense hasn’t tracked my sleep since daylight savings. Anyone else have this issue? How can I fix it? It’s fully charged and on my wrist correctly and it was recording my sleep perfectly before the time change.
Moderator edit: clarified subject
Best Answer11-12-2024 06:54 - edited 11-12-2024 07:01
Hi @Rebeccapeterson. Welcome to the community forums.
Thank you for providing this information regarding your Sense.
I'm not sure if you are still experiencing this difficulty. If so, I'd recommend you restarting the device as indicated here: How do I restart my Fitbit device?
Please make sure of the following:
Try adjusting the sleep sensitivity on the Fitbit app and check if you continue to have the same difficulty.
In addition, please wear your device on your non-dominant hand and monitor it for the next few days.
