01-17-2021
18:45
05:18
WilsonFitbit
01-17-2021
18:45
05:18
WilsonFitbit
This just started a couple weeks now, stuck at 100% last a couple days ,doesnt show any other power then dies with no warning. Also takes forever to charge when that happens. Any advise
22:40
08:11
01-17-2021
22:40
08:11
Firstly, A completely discharged watch takes longer to charge.
Secondly where are you seeing the 100% battery?
Thirdly, to check.
A [or any] day after you fully charged the watch and
With the watch synced
In the phone Fitbit App Click on profile photo [top left] Device photo [middle left] Sync - See when last synced Try refresh by touching circle it should say "a moment ago" |
Return to the Today tab [main screen] of the Fitbit app and pull down on the screen
It will momentarily show the watch battery percentage on the app status bar at the top.
It should not say 100%, unless you just charged it.
Best Answer01-17-2021 22:41
01-17-2021 22:41
Have you tried a different clock face. I’ve noticed some of the clock faces are quite buggy.
22:49
08:10
01-17-2021
22:49
08:10
05:17
08:10
01-18-2021
05:17
08:10
Hello @DjCram Welcome to the Community Forums! @Guy_ @Bauer24 I appreciate your input!
@DjCram It is possible that the difficulty might be related with its battery so I also recommend taking a look and follow the steps provided in this help article: Why isn't my Fitbit device's battery charging?
Keep me posted.
Best Answer01-18-2021 07:24
01-18-2021 07:24
Ok, after writing this I tried again powering off the watch. This time when It came back on it showed 64% instead of the 100% battery. I will keep track and see if this happens again. Maybe it was just stuck, will report back if happens again. Thanks for the advise above
Best Answer01-18-2021 08:38
01-18-2021 08:38
Thanks for the update, looks like progress.
03:32
08:10
01-20-2021
03:32
08:10
@DjCram I appreciate your efforts!
I hope you can continue tracking towards your fitness goals without any inconvenience.
See you around!
