04-30-2024
05:46
08:14
04-30-2024
05:46
08:14
HELP!! sense won't sync and have a big X with message- Data not cleared, sync and try again.
Anyone know what to do?
Best Answer04-30-2024 08:16
04-30-2024 08:16
Hi there, @Sceeterbug. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post. I'm sorry to hear that your Sense is stuck on that message. I will do my best to help you with this!
Please note the message you're receiving usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, I'd recommend trying the steps below in the order listed:
If you can't get started with your Sense, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
