08-05-2021
16:09
04:52
WilsonFitbit
08-05-2021
16:09
04:52
WilsonFitbit
My Fitbit Sense is vibrating every single day with an alarm at 5am. Of course, I don't set an alarm at 5am. I contacted CS they supposed to go back to me through an email but nothing. I did restart my Fitbit, but still have the problem 😞
Moderator edit: subject for clarity/format
Best Answer08-05-2021 15:59
08-05-2021 15:59
I know this post is fromlong time ago but my fitbit sense has the same issue, alarm at 5am every single day. Whats wrong with fitbit?? You should really do a proper follow up.
Best Answer08-05-2021 20:45
08-05-2021 20:45
Hi, by chance is it an alarm from your clock face rather than from the alarm app?
To make sure it's not an alarm, when you swipe left on the watch and tap alarms, are there any entries? If so click on the entry, scroll to the bottom and click remove.
08-06-2021 01:22
08-06-2021 01:22
Another thing to check is whether you have set any alarms via the voice assistant as these alarms are separate from the normal alarms.
08-06-2021
04:54
11:14
08-06-2021
04:54
11:14
Hello @Gracedelas. Welcome to the community forums. @Guy_, @SteveH Nice to see you around and thanks for your input.
@Gracedelas I'm sorry for the experience and thank you for the detailed information and for the troubleshooting steps you've followed. I was able to confirm that you reached out to our Support Team and they are currently working on your case. In this case, I'd recommend keeping an eye on your inbox since they should get back to you with more information soon.
If you still have additional questions or inquiries, please make sure to let them know so they can continue assisting you. Thanks for your patience.
See you around.
08-07-2021 09:03
08-07-2021 09:03
Thanks a lot @WilsonFitbit, waiting for your email.
08-07-2021 09:04
08-07-2021 09:04
Thanks, Steve. I dont have any set alarm through voice assistant because I did the restart my fitbit from factory.
Best Answer08-07-2021 09:06
08-07-2021 09:06
Hi, Guy. There are no entries. I sent a picture of that to the fitbit's support team.
Best Answer08-10-2021 20:50
08-10-2021 20:50
Hey, once again the alarm was at 5am. How come is this possible if I restart my fitbit from factory?! This time I was able to take a pic but I cant find the option to attach it. Looks like you havent done anything at all since I report this.
21:05
11:13
08-10-2021
21:05
11:13
When you post there are icons along the top, and the one that looks like a picture frame enables you to attach a photo.
Have you tried to set an alarm during the day using the alarm app on the watch to see if the display is the same as the 5am one?
At least then you will know it's the app doing it or not.
Presumably the alarm is not coming from your phone? You can check this by turning your phone off for a night.
08-10-2021 21:10
08-10-2021 21:10
Since I restarted my fitbit from factory, once again Ill confirm I havent set any alarm at all.
(When Im posting here theres no picture frame. I see an arrow to go back, a letter B, letter I, the three lines icon and another to attach a link, no pictureframe).
Best Answer08-10-2021 21:11
08-10-2021 21:11
The alarm is coming from the fitbit.
21:35
11:13
08-10-2021
21:35
11:13
How most annoying having an alarm you can't stop.
Click the attach link icon then attach the photo.
08-11-2021 00:15
08-11-2021 00:15
Are you sure it's an alarm and not some other notification? I remember a post in the past when someone had set their daily goal to be a number of calories rather than a number of steps and they met this goal in the early hours. Such an alert would still be active after a factory reset (as long as it was reconnected to your account)
