Can anyone tell me what the watch face size is for a Sense? I want to purchase and band and it says it is compatible with a 38mm 40MM 41mm watch face. I looked in the manual and didn't find it. Thanks.
Best AnswerHi, @PCohen, welcome, You need bands that state clearly they are compatible with Fitbit "Sense" as the fitting is a proprietary design fitting in a slot about 24mm long. Third-party bands may serve you well but if it fails or disconnects say goodbye to your "Sense".
I hope this helps.
Cheers
Gr4ndp4 | UK
I hope this helps.
Cheers
Gr4ndp4 | UK
