01-29-2021
18:59
07:00
WilsonFitbit
01-29-2021
18:59
07:00
WilsonFitbit
Hey. I've had the fitbit sense for less then a week. So far it's awesome but one issue that's happened the past 3 days is when I log the amount of water on the watch everything works like normal but at some point thruought the day it stops logging and just shows 0. If I try to add more it will still show 0. One thing though is the app on my phone will display the correct number but the watch does not.every morning it works like normal but the issue just repeats as the day goes on.
I'm using the pixel 4a 5G and the watch firmware is up to date. I've tried restarting the watch and my phone and that doesn't fix the issue.
Thanks!
Best Answer01-30-2021 06:59
01-30-2021 06:59
Hello @Whofarted, welcome to the Community Forums! Thank you very much for the information and the troubleshooting steps you've followed prior to posting!
Please try to remove the water tile on the Fitbit watch. For this, please do the following:
- Go to the Today app on your Sense.
- Scroll down and tap on Edit.
- Look for water and tap on it. (You will see it now will appear under Add to App) Tap on save.
- Sync your Sense and then add the water tile following the steps above and test it.
Keep me posted.
Best Answer01-30-2021 09:46
01-30-2021 09:46
Best Answer01-30-2021 16:58
01-30-2021 16:58
Hey Wilson, I tried the steps you recommended and the Issue is still happening.
01-31-2021 11:17
01-31-2021 11:17
Adding to this chain that it affects me too! It’s much easier to log on the watch the water consumed but then it doesn’t maintain the log throughout the day and you’re back to 0! Very frustrating.
02-01-2021 10:22
02-01-2021 10:22
Hello everyone. @Flamboyant it's great to see you around!
@Whofarted @Flamboyant thanks for your continued reports and feedback. Our team has been informed of this situation experienced with the Sense not saving water logs and they're investigating what may be occurring. I apologize for the inconvenience this has caused you, your comments haven't gone unnoticed and be sure they'll be passed along.
See you around.
Best Answer02-03-2021 06:10
02-03-2021 06:10
I am also starting to face this problem today, and the situation remains even after trying the suggestion.
Best Answer02-03-2021 08:37
02-03-2021 08:37
Hello @lemayp, it's nice to see you again here in the forums!
I'm very sorry for the experience. I hope a resolution can be found for this inconvenience soon. In the meantime, please try logging your water through the Fitbit App. Thanks for your patience.
See you around.
Best Answer06-24-2021 23:13
06-24-2021 23:13
Has this issue been resolved? I just purchased the sense and have used it for 2 days now and it will not log water on the watch. It goes to 0. Thank you.
06-25-2021 13:44
06-25-2021 13:44
Unfortunately, it's still around, even with the newest Fitbit OS version 44.128.5.38. I guess Fitbit doesn't see this issue as something that needs fixing 😔
06-25-2021 14:06
06-25-2021 14:06
07-14-2021 18:16
07-14-2021 18:16
I know. I feel like going back to my versa 2
Best Answer07-25-2021 19:40
07-25-2021 19:40
Hi Wilson,
Has there been an update to resolve this issue.. I just upgraded from my charge 4 to the sense and had it for 3 days now... And I am experiencing the same issue...
08-11-2021 18:43
08-11-2021 18:43
Hi, I have had mine for 2 weeks and it only started happening after the latest update. Ive tried a few different reccomendations and nothing has worked.
Best Answer12-05-2021 17:23
12-05-2021 17:23
I'm new to the smartwatch family, an early Christmas gift to myself...
I've only had mine about a week. It started out fine & just noticing this same issue within the last day. It's nice to be able to just look at the watch to see where you're at on your water intake & not have to go into the app. Hopefully it gets resolved. Everything else so far is great!
12-20-2021 06:15
12-20-2021 06:15
Also having this problem and very unhappy to see others have been having it for 6 months without a resolution. I can log water on the watch and it is reflected in the app on the phone, but the watch immediately goes back to showing 0. If I log water on the phone it stays on the phone but does not show up on the watch. VERY DISAPPOINTING. I’ve tried removing and replacing the water tile, and restarting the watch. No help. By the way, restarting the watch screws up so many other settings I’m loathe to try it again! I am now thinking I spent a lot of money for something that makes me take out my phone more instead of less.
08-24-2022 20:01
08-24-2022 20:01
Hi Wilson,
it’s now August 2022 and I just got the Sense less than a week ago. And it is also having the same problem. Furthermore, it zeros out when I log through the watch but will update on the app.
I’ve done so much trouble shooting via messaging and phone calls that I’m extremely frustrated.
Please tell me there is something that can resolve the issue.
