10-27-2020
23:04
17:05
LizzyFitbit
10-27-2020
23:04
17:05
LizzyFitbit
Problem is stuck with one clock face
when change of clock face
"unable to update / install one or more apps. Please try again".
The communication between the fitbit device and the app seems to be fine so I am not sure what this is referring to. What do I need to do? Is this a glitch with the update?
tried to take shutdown, restart iPhone nothing helps
31/10-20
can see that i can change clock face in app , butt no longer on clock, then it hang and must in app to change
Best AnswerThis is genius, thank you. Same thing has been driving me mad for weeks and it turns out it was all because I was using the "short-cut" instead of the main menu.
