Hi @Pdbass - this can be an issue with cleaning or the charge able, see how to deal with it, How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Best AnswerI'm also seeing the same issue. Tried cleaning the contacts via the recommended methods but no joy.
I've owned the Sense only 5 months.
I suspect in my case one of the pins on the charger cable is slightly pushed in, so when I try and click it in, the charging indicator flashes up for a second before reverting back to my usual screen.
Personally I am not impressed with the Sense. Two things wrong with it, 1) The charging mechanism just sucks, this click magnetic mechanism is a joke, more often than not the magnet repels making it tricky to plug in. The Versa charging mechanism was fine, why did they change it to be more cumbersome ? Fit Bit really need to move with the times go wireless charging or make the mechanism simple.
2) More of a moan but having to subscribe to a music service to listen to tunes is poor.
I've been a lifelong FitBit user but seriously considering my options here.
If your item is within warranty naturally contact fit-bit support
