06-20-2021
06:32
09:15
LizzyFitbit
06-20-2021
06:32
09:15
LizzyFitbit
I just bought my Sense on friday for my birthday and can't even use it. I was so looking forward to it. I had an ionic for 4 years and never had problems with it. I'm not impressed at all. After all i so wanted to buy the Sense and now i feel like i want to take it back. I hope this problem will be solved too. I tried everything what they recommended but it still doesn't work.
Moderator Edit: Clarified subject and updated label
Best Answer06-20-2021 12:47
06-20-2021 12:47
Hi @EdinaJ I get the impression you have something other than a problem with notification so I've moved your post to its own thread.
You say that the sense doesn't work? What about it that doesn't work? Do you get any error messages?
06-21-2021 01:39
06-21-2021 01:39
Hi Rich. When i set up the device i can't connect to the wifi. I did set up evrrything for notifications but i don't get any. I haven't got any error messages on the watch. But when i try to connect to sense control my phone says it can't connect. I unpaired every Fitbit device and deleted my device from the app. Uninstalled the app, restarted the phone and the watch and set up everything from the beginning. But i still can't connect to wifi and sense control. The wifi works everywhere else in the house. That can't be the problem. I use wifi on my phone. I have a Samsung Galaxy S10 Plus by the way. I can see my activity on the watch and in the app. I really don't know what else i should try. I'm still waiting for that notification issue to be solved.
06-30-2021
08:44
07:26
06-30-2021
08:44
07:26
Hi @EdinaJ. Welcome to the Community. @Rich_Laue Thanks for stopping by to help our friend.
@EdinaJ I'm sorry for the difficulties you've experienced with your Sense and thanks for every step tried prior to posting. Usually the Wi-Fi, Sense Controls or notifications won't work if the Fitbit device isn't syncing correctly or if there are other Bluetooth connections turned on nearby. That being said, could you confirm if the issues persist? If you do, I'd recommend the following steps as last resort:
Once this is done, try adding your Wi-Fi network to your Sense, setting up the notifications and the on-wrist phone calls. Let me know how it goes.
Hope this helps.
Best Answer06-30-2021 21:30
06-30-2021 21:30
Hey @LizzyFitbit . Thanks for asking. I could make it work finally. I kept trying everything and after a few days it started working.
07-01-2021
10:42
07:28
07-01-2021
10:42
07:28
Hi @EdinaJ. It's good to see you again.
You're welcome. I'm glad your Sense started working again and thanks for your efforts while working on this matter. I hope you continue enjoying the experience with your watch and let me invite you to visit our Health & Wellness board where you can find great tips and encouragement from other members to have a healthy lifestyle.
Have a great day! 🙂
