10-08-2023
16:25
07:37
10-08-2023
16:25
07:37
The app updated and my sense wouldn't sync properly, so I tried to disconnect the Bluetooth. When I went to connect the app, my phone wasn't recognizing it. It still recognizes my watch though.
10-09-2023 07:38
10-09-2023 07:38
Hi there, @Happy312. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Sense and your time in trying to troubleshoot it.
In addition to the steps you've done so far, please try the following in the order listed:
Before trying the above, please be aware that most Fitbit devices store up to 7 days of detailed minute-by-minute data. If you wait longer than 7 days before syncing, you may only see the most recent week's detailed data. Summary data (calories, distance, steps, and floors) will be stored for 30 days. Nevertheless, if your Fitbit device was unpaired from your Fitbit account during this period of time, neither the 7 days can be recovered or restored.
10-10-2023 14:59
10-10-2023 14:59
These steps do not work. I have followed them multiple times. I am able to get the 4 digits on the Sense display. The Fitbit app then says "connecting to Fitbit". This message never changes. Then there is an error message "Something went wrong. There was an error while trying to pair your device. Abort. When I check my bluetooth devices the Sense is paired and I can receive messages from my Iphone. However, the fitbit app is NOT paired. Please suggest another fix.
10-10-2023 15:37 - edited 10-11-2023 06:13
Hello there, @Marybawesome. Thanks for stopping by in the Fitbit Community Forums and sharing the details about the issue with your Sense.
I appreciate you've taken the time to try the steps I shared above. As our last resort, I'd recommend performing a factory reset on your Sense. To do so, on your Fitbit device, open the Settings app > About > Factory Reset.
Once the above has been done, you can now proceed to set up your Sense again by following the steps provided here How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
10-10-2023 16:33
10-10-2023 16:33
YES! This worked. Thank you!
10-11-2023 06:14
10-11-2023 06:14
@Marybawesome You're very welcome! I'm glad to hear you're back on track now. 😊
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
10-11-2023 19:27
10-11-2023 19:27
Does anybody bother to test these updates before rolling them out and causing all these issues? Having to mess around with all these things to try to get a product back to a working state is ridiculous and a complete waste of time.
This is quite nice!
Wouldn't sync.
10-12-2023 09:56
10-12-2023 09:56
@jgtwrites wrote:Does anybody bother to test these updates before rolling them out and causing all these issues? Having to mess around with all these things to try to get a product back to a working state is ridiculous and a complete waste of time.
The Bluetooth sync issues started way before the new app rolled out.
10-12-2023 19:51
10-12-2023 19:51
Ok. Your point is what? My question is not valid because it does not fit your time period?
10-13-2023 06:09
10-13-2023 06:09
@jgtwrites wrote:Ok. Your point is what? My question is not valid because it does not fit your time period?
Easy there, easy. I was only stating that the Bluetooth sync issues have nothing to do with the recent FitBit app update. Many people started having sync issues long before the new app rolled out.
