11-10-2022
11:50
12:40
11-10-2022
11:50
12:40
i have the a problem with my fitbit Sense (lost Bluetooth paring) since 2 months even after update the app ... (Iphone)
Best Answer11-11-2022 12:42
11-11-2022 12:42
Hi there, @ahmedaziz202. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Sense.
If you haven't done so yet, I suggest following the tips and recommendations provided here Why won't my Fitbit device sync?
Hope that helps.
Best Answer11-12-2022 06:06
11-12-2022 06:06
Thanks a lot, I did it many times … it’s working but still lost Bluetooth paring from time to time and I have to repeat that again and again…… my iPhone and sense app is up to date…. I don’t know what can I do …
Best Answer11-12-2022 06:49
11-12-2022 06:49
Hi, @ahmedaziz202, have you loaded the latest Fitbit iOS version 3.70?
Let us know.
Cheers
Gr4ndp4 | UK
Best Answer11-12-2022 07:23
11-12-2022 07:23
hi, tanks for your interest, iOS and Fitbit app is up to date
Best Answer11-12-2022 09:01 - edited 11-12-2022 09:03
@ahmedaziz202 Thanks for following the tips and recommendations provided above. @Gr4ndp4 Thanks for helping out!
I'd like to know if you have any other devices connected to your phone's Bluetooth that you use frequently? If so, I'd recommend trying the following:
1. Remove the Fitbit device from your phone's Bluetooth settings and in the Fitbit app.
2. Remove other devices that you may have connected to your phone's Bluetooth settings.
3. Restart your Fitbit device.
4. Turn off other Bluetooth connections when not in use.
5. Plug it into the charging cable and open the Fitbit app.
6. Set up your Fitbit device.
7. Once you make sure that your Fitbit device is connected and syncing, please link your other Bluetooth devices to your phone.
Hope that helps.
Best Answer11-12-2022 09:45
11-12-2022 09:45
Thanks a lot..: done all the above steps…. But still losing paring from time to time … same story… I us Fitbit blaze since 2016 never happened like this one I change to Sense I have trouble…. I know Fitbit company part of google…. I have a bad experience with that model ……….
11-13-2022 09:33
11-13-2022 09:33
Hi,
I still have same issues… really it’s a bad experience with Fitbit Sense … where is the technical support team…..? Waisting money and time
11-13-2022 10:21
11-13-2022 10:21
Hi, @ahmedaziz202, you will have noted that the Fitbit Blaze is a substantially different device from the Fitbit Sense. The Fitbit environment has advanced at least two generations during this time. This is a community forum where volunteers (like myself) and moderators provide advice.
Allowing you have followed the advice from @MarreFitbit and are on iOS 3.70 and you are still stuck I suggest you talk to "Customer Support" using the chat facility or phone for a prompt response.
Cheers
Gr4ndp4 | UK
10:43
05:55
11-13-2022
10:43
05:55
I really appreciate your help Gr4ndp4
Update:
Thanks @Gr4ndp4 for your interest I really appreciate… the problem already sorted out.. The problem that I turned off location services on my mobile setting once I turned it on Bluetooth is working perfectly …. Thanks for your efforts and appreciate for all Fitbit community people
thanks for all of you
best wishes
Moderator Edit: Formatting & Merged Posts
