03-29-2024 01:53
03-29-2024 01:53
Hi ..
I bought my sense in June 2021 after upgrading from versa..till now I have never used the watch in water..
Couple of weeks back I was washing dishes while wearing the watch and it was exposed to water for few minutes..since then it has stopped working ..won't turn on at all.
This is my fourth fitbit and never experienced something like this before..
Can someone please suggest any troubleshooting tips or how to get it going again..
Best Answer03-29-2024 05:54
03-29-2024 05:54
Hi @Hardeep41 - in all likelihood the watch got water in it and is damaged.
If it gets hot while charging stop immediately.
If you charged it for 2 hours from a PC power source and then holding the button for 10 seconds it does nothing it is probably dead.
Just in case check How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
It is extremely unlikely the 2 events occurred at the same time.
Best Answer03-29-2024 17:06
03-29-2024 17:06
Guy - Your answer doesn’t make sense, since the sense 2 is water resistant to 30 meters.
i am having the same issue with incorrect time on clock and did not get my sense 2 wet. Other suggestions?
Best Answer03-29-2024 20:10 - edited 03-29-2024 20:11
Hi @barbalona - this topic is about a watch not starting because it got wet and doesn't apply to your situation, but try these links to resolve your time problem.
How do I change the time on my Fitbit device?
Why won't my Fitbit device sync?
