05-09-2025
03:51
07:17
05-09-2025
03:51
07:17
My Sense watch keepts disconnecting bluetooth connection with iphone, It disconnects every night, and 2 or 3 times a day
every time I have to go to settings and "forget" the device
and then back to the app to refresh
ANyone got a perminant fix?
Best Answer05-09-2025 07:21 - edited 05-14-2025 06:01
Hi there, @aaedwa. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Sense won't stay connected to your iPhone's Bluetooth. I understand your concern, I will do my best to help you with this!
In addition to the steps you've done so far, I'd like to confirm that you've tried all troubleshooting steps provided here Why won't my Fitbit device sync?
05-13-2025 03:29
05-13-2025 03:29
Hi
the watch is a Sense if that makes any difference
I have tried all the steps. Not I can get the watch to sync by forgetting the device under Bluetooth settings on iPhone. My problem is that it keeps dropping connection
Best Answer05-14-2025 06:09 - edited 05-14-2025 06:09
@aaedwa Thanks for getting back to me and for the update. I appreciate you had tried all the steps I recommended above.
If you haven't done so yet, I'd recommend trying the following in the order listed:
With the steps above, what I want you to do is to pair your Sense first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
05-23-2025 16:22
05-23-2025 16:22
I have had that problem many times, usually after changing to a different Fitbit. Try resetting the watch by holding the side button for 10 seconds, then let it reboot. That clears the memory of any other bluetooth connection.
