06-23-2021
14:38
10:03
WilsonFitbit
06-23-2021
14:38
10:03
WilsonFitbit
Every time I want to sync I have to pair with my Bluetooth again. Why? I’ve had to do this for 3 days now and practically every hour.
Moderator edit: Subject for clarity/Format
Best Answer06-23-2021 16:08
06-23-2021 16:08
What type of phone do you have?
Best Answer06-23-2021 16:16
06-23-2021 16:16
iphone 12
Best Answer06-24-2021 10:00
06-24-2021 10:00
Hello @bethc37. Welcome to the community forums! @lablover55 It's great to see you around and thank you for your input!
Thank you for the detailed information. It could be due to a connection issue and I'd suggest that you please try to turn off the Bluetooth on your phone and then turn it back on.
In addition, I'd recommend restarting your Fitbit Sense by following the instructions in this link and then, please force quit restart the Fitbit App. If that doesn't work, please go to Set Up a Device in the Fitbit App, choose your wearable Fitbit device and then tap on Replace Device. This will attempt to repair your watch or fitness tracker with the phone. Simply follow the instructions provided. Depending on the device that you have, you may be prompted to enter a 4 digit number to approve the connection.
If that doesn't work, please check these help articles for more information: How do I set up my Fitbit device?, Why can't I set up my Fitbit device?
Hope this helps.
Best Answer06-28-2021 06:28
06-28-2021 06:28
It seems to be working after I shut off my watch and turned it back on. It asked to pair but hasn't asked since so I think it is holding.
07-02-2021 09:03
07-02-2021 09:03
@bethc37 Thank you for your reply.
I appreciate your help for the additional steps you've tried. I hope you can continue tracking towards your fitness goals without any inconvenience.
See you around.
