01-06-2021
05:56
11:24
LizzyFitbit
01-06-2021
05:56
11:24
LizzyFitbit
Not synching. Not logging sleep. Receiving “not able to update one or more apps please try again” too often.
Best Answer01-07-2021 10:40
01-07-2021 10:40
Are you on the latest tracker firmware 44.128.4.17? See Latest Firmware list
Have you logged out of the Fitbit app and rebooted both watch and phone?
Best Answer01-07-2021 13:17
01-07-2021 13:17
Hi there, yes the Fitbit has the latest firmware. As this Fitbit sense was a Christmas gift I have had it for less than 2 weeks. I just received another error “we were unable to update or install one or more apps, please try again.” This error has happened quite often. I have rebooted my phone, turned off Bluetooth, forgotten device and re-launched it. Etc. When I pull down on the iPhone app it doesn’t synch.”couldn’t synch your sense” it is very frustrating as I spend a lot of time pulling down and trying over and over.
Best Answer01-07-2021 22:14
01-07-2021 22:14
Things to check
When you setup your watch for the first time that you succeeded in setting up a wifi connection?
[Wifi connections only work if the watch has more than 25% battery, and/or on charge]
You obviously had a Bluetooth connection at that time, to set it up.
You seem to have done all the right steps but keep losing the Bluetooth connection, can potentially happen if there is interference from other devices [routers] or the phone wasn't in proximity.
Check your phone is on the compatible phone list.
If it is probably best to contact Fitbit Support directly.They may be able to help you.
