03-18-2024
14:24
08:24
03-18-2024
14:24
08:24
I can’t get my sense Fitbit to sink into my phone app and I have tried turning off my phone and it still won’t work so I don’t know what is wrong with it.
Best Answer04-03-2024 17:02
04-03-2024 17:02
@Guy_ wrote:Hi @Rosa599 h this can be an issue with versions of the Fitbit App.
Try Logout of the Fitbit App and swipe off the active Fitbit window and in Android clear the storage cache and force stop it
This was all it took for us. The app would say it's syncing forever, but after doing this and starting the app again, the sync worked.
03-18-2024 21:14
03-18-2024 21:14
Try Logout of the Fitbit App and swipe off the active Fitbit window and in Android clear the storage cache and force stop it and then restart the phone.
Make sure there are no other devices running the Fitbit App switched on or other watches.
Restart the watch by holding the button for 10 seconds till it blanks or vibrates and the logo appears and wait for it to start.
Login and wait for any pair, link or Fixit prompts and sync. See also
Why won't my Fitbit device sync?
03-19-2024 08:29
03-19-2024 08:29
Hi there, @Rosa599. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Sense is still not syncing properly. We're here to help!
If the steps recommended by @Guy_ don't work, I suggest trying the following steps in the order listed:
With the steps above, what I want you to do is to pair your Sense first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer03-19-2024 10:06
03-19-2024 10:06
Mine is doing the samething! Have you get it working ?
Thanks Wanda
04-03-2024 17:02
